Velcnet
Jun 14, 2017Aspirant
Nighthawk x10 two questions
Greetings, have two questions about r9000: 1. How I can change time zone for router? 2. Looks like router restarting by himself sometimes. Log shows events after rebooting only. Is there any chanc...
- Jun 14, 2017
Is QoS enabled? Disable to see if router stops rebooting.
Jun 20, 2017Guru - Experienced User
The 5Ghz radios I presume is HW based and not FW based so this portion of the 5ghz band can't be modified.
Velcnet
Jun 21, 2017Aspirant
Thanks, FURRYe38,
Could you please advice what is the best:
1. Connect all 5GHz devices to 5GHz band (up to 8 devices). Can R9000 balance all these devices?
2. Switch devices, that don't require 5GHz speed to 2.4GHz band to have balance between bands.
Currently only I have 5GHz band and no other 5GHz networks are available. At the same time there are around 10 another 2.4GHz networks near me.
Thanks!
- VelcnetJun 21, 2017Aspirant
One more thing happened:
[DHCP IP: 192.168.0.103][Device Name: APPLE-TV] to MAC address , Wednesday, June 21, 2017 15:46:57 [DHCP IP: 192.168.0.103][Device Name: APPLE-TV] to MAC address , Wednesday, June 21, 2017 15:45:24 [DHCP IP: 192.168.0.103][Device Name: APPLE-TV] to MAC address , Wednesday, June 21, 2017 15:44:07 [DHCP IP: 192.168.0.103][Device Name: APPLE-TV] to MAC address , Wednesday, June 21, 2017 15:42:37
I read the same issue for Orbi, but looks like R9000 has the same issue too.
Ok, it was because of HT160 enabled. Once disabled it, such messages are gone.
Also have
[Internet connected] IP address:
messages every 10 minutes, but once to internet drops, looks like can ignore this.
Yeah, a bit strange router!
