Velcnet
Jun 14, 2017Aspirant
Nighthawk x10 two questions
Greetings, have two questions about r9000: 1. How I can change time zone for router? 2. Looks like router restarting by himself sometimes. Log shows events after rebooting only. Is there any chanc...
- Jun 14, 2017
Is QoS enabled? Disable to see if router stops rebooting.
Jun 21, 2017Guru - Experienced User
The X10 should be able to handle 5Ghz devices on it's radio well.
Ya, HT160 should be disbled if you don't have any supporting devices that connects at that rate.
- VelcnetJun 25, 2017Aspirant
Thanks, FURRYe38!
Last question - I have [Internet connected] log entry each 5 minutes.
Connection status: NETGEAR Router R9000
Lease Obtained 0 Days, 0 Hours, 10 MinutesI don't expect any connection breaks, but for me it's not normal.
Do you know if it can be router issue or it is only ISP provider issue?
- FURRYe38Jun 26, 2017Guru - Experienced User
Your seeing log entries every 5 minutes? Maybe a router behavior logging thing...
