Mikeme
Oct 14, 2018Guide
Nighthawk x10 WiFi signal interruption
As the title suggests, I am experiencing constant disconnects with my x10. To the point where every 20 minutes anything connected to the WiFi loses connection momentarily, then it returns. I hav...
- Oct 18, 2018
*Update*
After now going through 3 of these, and having the same issue. I have decided to dump this thing and get this: https://www.amazon.com/Linksys-Max-Stream-EA9500-802-11ac-Ethernet/dp/B017NT8Q24/ref=sr_1_14?rps=1&ie=UTF8&qid=1539882301&sr=8-14&keywords=router&refinements=p_85%3A2470955011%2Cp_72%3A2661618011
I have had an x10 for a little over a year now, and when it works its great. But it just has been sucking lately. So I am out. Peace!
zookeee
Oct 15, 2018Tutor
I'm having the same issue. Did the "smart connect" thing (which I am loathe to do) and it helped A LITTLE. I shouldn't have to do that though.
Went through this before. Finally "fixed" itself.
Mikeme
Oct 15, 2018Guide
What is the smart connect?
- zookeeeOct 15, 2018Tutor
It is where you set your wireless device names and passwords to the same thing and it will switch you to whichever has better service. It is a setting when you login to the router dashboard. Very poor way to describe it but it is 2 in the morning here and I am a layman here just looking for help on a different problem. Still would like answers to this issue though....
- MikemeOct 15, 2018GuideGotcha, lol.
I will give that a try and let you know. Today I also plan to wipe it again, and not reload the backup file and start from scratch.. again.
But with 92 devices it’s a real B to reconnect everything.- xnsysOct 15, 2018Luminary
Disable 802.11k (Smart Roaming)
It's in the Advanced / Wireless area.
- MikemeOct 15, 2018GuideSo if smart roaming and smart connect are the same thing, it looks like a bit of contradictory info.
But since that setting was already disabled, I’ll go ahead and enable it and see what happens.- xnsysOct 16, 2018Luminary
No...Smart roaming and smart connect are two seperate things.
One is found under Advanced > Setup > Wireless settings (Smart Connect), the other is found under Advanced > Advanced Setup > Wireless Settings.
