1c3m4n_MJ
Jul 28, 2021Aspirant
Nighthawk X10
Newbie - I see a similar question asked before - so apologies but I have the same problem and I don't think this is firmware related. I've had the R9000 for a couple of years after a recommendati...
1c3m4n_MJ
Jul 29, 2021Aspirant
Thanks for your reply.
I don’t think it’s the firmware because I had this problem before I upgraded to the latest.
There is a fan directly behind the unit and it’s next to an open window, so it couldn’t be in a better position.
Regarding power, it’s connected to a UPS on the “surge only” supply so it’s getting clean regulated mains.
Reboots are completely random and I’m really convinced that no internal fan inside the router has ever come on. Are these units passively cooled by way of a heat sink or do they have integral fans?
I’m sure this is a faulty unit now
fire888
Sep 20, 2021Guide
ok. so I finally found the answer.
It was THE PRINTER.
When I unplugged the printer, the router functioned normal again at last.
I have tried this for almost a month, and it's all good.
So, if u have the same problem, u could try to unplugged the printer.
It's not so good anyway. Netgear's printer feature is awkward at best (or at least on my R7000P).
So this case is closed.
But I just want to say, I found that netgear's support is dissapointing, and I feel like I've been cheated.
I bought this router because of netgear's big name, and I though I have a year (free worry) warranty.
So as u can see from the date of this thread, this problem happened at jul-aug 2021, and if the warranty is a year, then I should still under warranty until around mid-late sept 2021.
But netgear denied the support, and said that technical support only 90 days after purchased.
It's so weird to have warranty for 1 year (or even 2 years as the support said), but technical support only 90 days.
It was a nightmare trying to find the cause and support for this problem (for 2-3 months), and I was ready to throw this router away or even sell it cheap as garbage, luckily I found the cause myself, and it cost me to not use 1 of the feature (well which is not good implemented anyway).
I dont think I will want to buy netgear's product anymore. 1 time is enough.
- plemansSep 20, 2021Guru - Experienced User
I'd agree that the "support' part of it is a bit bogus. I really wish they'd do a better job of explaining it for people.
Its a challenge as the most of times that people are having issues, its not related to the router at all or is with something that could be solved with a quick search or going through a manual. And running a call center with people competent isn't cheap either.
They do they 90 days so its enough for people to get a product up and running. If it powers on after that 90 days, then its a paid thing. Unless it truly is a hardware issue. Then my understanding is they refund the support charge. I've never needed to use it but its always an option.
- fire888Sep 21, 2021Guide
plemans wrote:I'd agree that the "support' part of it is a bit bogus. I really wish they'd do a better job of explaining it for people.
yeah 90 days were enough to get the product up and running, but not really enough as the product would likely start to behave wrong in a few months after used, or even on almost 1 year.Most practice is that the support should be just as long as the warranty, that's at least 1 year. 1 year warranty is almost just a sham when the support not there.anyway I apologize, my previous comment was misplaced thread.seems like netgear forum was getting weird yesterday.It was supposed to go to my thread not this thread, and I can swear I never opened this thread before, so there's no way I was the one who posted it on this wrong thread.
