LTHolyoke
Jul 09, 2023Aspirant
Nighthawk X4 AC2350 - does it have a fan?
About the Nighthawk X4 AC2350 Smart WiFi Router .... 1. Based on searching for "fan" in the full user manual for this router, it appears it does NOT have a fan in it. Is that correct? 2. As...
- Jul 10, 2023
Is that audible or loud?
is the sound coming from the router box unit or the power adapter?
If the sound is coming from the router box, then maybe time for a new router. Nothing can be done for odd noises coming from the router box inside.
michaelkenward
Jul 09, 2023Guru - Experienced User
LTHolyoke
"Model R7500v2" it says underneath.
