llmatt123
Aug 26, 2022Tutor
Nighthawk X4 AC2350 Smart WiFi Router Model R7500
I've installed a new Ring Security System and connected the base station to my router with the supplied ethernet cable. In doing so, I get an orange blinking led light on that ethernet port. I've c...
- Aug 26, 2022Orange light on the router's LAN port(s) indicates it's operating at 10 or 100 Mbps speeds instead of 1 Gbps (white light). Nothing to worry about. Your station most likely uses a 100 Mbps network chip inside.
microchip8
Aug 26, 2022Master
llmatt123
Aug 27, 2022Tutor
Thank you for this confirmation. Good to know all is well.
