Rusticphoenix
Sep 06, 2023Follower
Nighthawk X4 AC3200 cannot connect to 5G
The only band that works for me is 2G. 5G shows with a strong signal but constantly says incorrect password or unavailable. I’ve confirmed the password is correct, tried scanning QR code from the app...
Sep 06, 2023Guru - Experienced User
What wireless device are you using?
Be sure to forget the SSID profile on the mobile device your trying to connect to it.
Besure your using WPA2 and AES only on the router.
Try a simple password like> Password123 <to see if this works. Let us know if this works.
Avoid using any special characters for now.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-route
