Rusticphoenix
Sep 06, 2023Follower
Nighthawk X4 AC3200 cannot connect to 5G
The only band that works for me is 2G. 5G shows with a strong signal but constantly says incorrect password or unavailable. I’ve confirmed the password is correct, tried scanning QR code from the app...
michaelkenward
Sep 06, 2023Guru - Experienced User
What Netgear device do you own?
X4 AC3200 isn't a useful indicator.
AC3200 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
