JM3F
Jul 07, 2021Tutor
Nighthawk X4 (AC3200)...can't connect to 5G
So I have a Nighthawk X4 (AC3200) Wifi Cable Modem Router that recently decided that it cannot connect devices to the 5G band. Same devices can connect to 2.4G. 5G is visible and signal appears strong, yet the devices can't connect. Tried resetting a few time without success. Tried changing channels without success. When I remove security from the 5G, the devices can connect, but I don't want to leave without security.
Any ideas...I'm about to throw this thing against a wall.
- JM3FTutor
BTW...this is a C7500 WiFi modem/router combo.
- DarrenMSr. NETGEAR Moderator
Make sure you dont have special characters in the password and that is set wpa2. You also may want to try and change the wifi name
DarrenM
- JM3FTutor
Password haven't changed...it worked fine until recently and no special characters used. Was the same as 2.4G, but I changed it and made no difference. Same with WIFI SSID names.
I'll try changing them both again, but I'm not understanding why it would make a difference if it had worked fine for a year?
