genes161
Oct 23, 2022Aspirant
Nighthawk X4 R7500 AC2350 DNS problem
Can someone pls help me? When I turn on "Enable Access Point Mode" I get this dns problem and cant use the router. I can only connect to the second router that I have in my network. The nightha...
Oct 23, 2022Guru - Experienced User
You need to have something on the network controlling dns/dhcp/net.
so if you put a router in AP mode, it disables all that and it relies on a different router to control it.
so it needs to go modem/gateway/routing device------>router in AP mode
And the device in AP mode, needs to come after the router managing it. Not before.
- genes161Oct 23, 2022AspirantSo, on the first router, my Netgear, this box gonna be unchecked?
- plemansOct 23, 2022Guru - Experienced User
correct. the first "router" connected to the modem should be in router mode. 2nd one should be in access point mode.
What is your full setup?
What modem/gateway do you have?
then what router?
Then you're connecting the r7500 to that router?
My second router is a dovado pro, old (2015)
But cant find access point in that one, guess it called something else, dhcp maybe?
