mb139's avatar
mb139
Nighthawk X4 R7500 forgets settings
I have had a Nighthawk X4 for just under a year.  Recently, somethign happened to the router and now every time the router power cycles, it defaults back to the factory settings.  It doesn't matter w...
  • mb139's avatar
    mb139
    Sep 15, 2015
    Update: After working with Netgear tech support for around 70 mins, they confirmed that this is a hardware issue covered by the 1 year hardware warranty.  If you have to call in past the 90 days for provide Tech Support, they will require you to give a credit card number for an "extended tech support" plan.  You are only charged if they find the issue not to be hardware related.
    I was a little put off by this, especially since the cheapest plan is $80 (6 months of tech support - this is different than the warranty).  However my issue was confirmed to be a hardware issue and I will be getting a replacement router free of charge and was assured that I would not be charged the $80 for tech support.
    Overall support could be a little more customer friendly (because of the tech support thing) but I was able to get my issue taken care of free of charge.  Just me prepared to be on hold a lot and have a computer connected to your router.
    Thanks!
