dzemik
Mar 09, 2017Aspirant
Nighthawk X4 R7500 problem with LAN
Hi, I am using Nighthawk X4 R7500 router almost a year without any special problems. But last week something changed. Most of my devices connected by cable were with wrong IP adress, outside defined...
- Mar 30, 2017Hi, until today router is working fine, no problem with IP adresses. So I have no idea what was that. Nothing changed in my network, same devices, same settings. I did not restart firmware, only few restarts during two weeks of mulfunction.
For today we can close the case.
Grzegorz
dzemik
no, I not changed password ... why I should do it?
but I will try that ... I have no better idea
LeeH
Mar 09, 2017Prodigy
The default admin account with password is well known and hackers will use this to log into your router and could be changing it or even loading their own hacked version of firmware.
- dzemikMar 10, 2017Aspirant
ok ... now I understand you ... of course when I set up router I changed default password :)
What you think about this IP that are set not local for cable connection, but outside my network, taken from internet provider?
Should be that only router have outer IP ... I can forward to other devices, but I not done it in this case
- schumakuMar 10, 2017Guru - Experienced User
dzemik wrote:What you think about this IP that are set not local for cable connection, but outside my network, taken from internet provider?
These aren't from the ZeroConf (169.254.0.0/16) range?
no ... example no. is 84.213.157.... I know that these numbers belongs to my internet provider
