dzemik
Mar 09, 2017Aspirant
Nighthawk X4 R7500 problem with LAN
Hi, I am using Nighthawk X4 R7500 router almost a year without any special problems. But last week something changed. Most of my devices connected by cable were with wrong IP adress, outside defined...
- Mar 30, 2017Hi, until today router is working fine, no problem with IP adresses. So I have no idea what was that. Nothing changed in my network, same devices, same settings. I did not restart firmware, only few restarts during two weeks of mulfunction.
For today we can close the case.
Grzegorz
ElaineM
Mar 14, 2017NETGEAR Employee Retired
What kind of IP addresses are you getting?
Supposedly, your LAN devices or devices that are connected to the router should have a local IP address range of 192.168.1.x or 10.0.0.x.
If you're getting anything other than that then something is not right with the setup or configuration.
Did you try to reset the router?
How about reflashing/re-uploading the latest firmware of the router?
