anyrules
Sep 21, 2015Aspirant
Nighthawk X4 R7500 WPS
Hello, I bought a Mitsubishi air conditioners with wifi adapter. I would like to connect the mentioned device to my home network via WPS. The connection has been created successfully, but the dev...
- Oct 05, 2015
Hello James,
Yes like to Mitsu devices with other router..
Istvan
nick1802
Jan 09, 2017Tutor
Hey james, don't no if anyone is still following this or not but I'm having a similar problem. What anyrules listed of tested routers is from the aircons website.
I am able to get mine to connect to the d7000 but then for some reason the device gives error lights saying it failed to get to the internet. Any help?
JamesGL
Jan 18, 2017NETGEAR Employee Retired
Hi nick1802,
Please post your concern under the DSL board.
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
