anyrules
Sep 21, 2015Aspirant
Nighthawk X4 R7500 WPS
Hello, I bought a Mitsubishi air conditioners with wifi adapter. I would like to connect the mentioned device to my home network via WPS. The connection has been created successfully, but the dev...
- Oct 05, 2015
Hello James,
Yes like to Mitsu devices with other router..
Istvan
netwrks
Sep 21, 2015Master
Use WPA2-PSK [AES]. Ensure the password is correct. Looks like that is what the message is referring to. Hopefully, you have created your own password / wifi passphrase and are not using the router defaults..
- anyrulesSep 23, 2015Aspirant
Hello, I'm using the WPA2-PSK [AES] with different password from the router default. As I know the password of the wifi should shared with the device adapter during the pairing
- JamesGLSep 24, 2015NETGEAR Employee Retired
Hi anyrules,
Welcome to Community!
Does it work when using a different security option? The Airconditioner might not be compatible with WPA2-PSK[AES].
JamesGL
Community Team
- anyrulesSep 25, 2015Aspirant
Hello JamesGL,
only with open network. The name of the device: MAC-558IF-E which is should capable of WPA2-AES encryption.
Please see the installation guide: http://www.mitsubishi-electric.co.nz/materials/Controllers/Manuals/WI-FI/1_Operation/Guide_Wi-Fi_Control_Installation.pdf
Istvan
