anyrules
Sep 21, 2015Aspirant
Nighthawk X4 R7500 WPS
Hello, I bought a Mitsubishi air conditioners with wifi adapter. I would like to connect the mentioned device to my home network via WPS. The connection has been created successfully, but the dev...
- Oct 05, 2015
Hello James,
Yes like to Mitsu devices with other router..
Istvan
anyrules
Sep 23, 2015Aspirant
Hello, I'm using the WPA2-PSK [AES] with different password from the router default. As I know the password of the wifi should shared with the device adapter during the pairing
JamesGL
Sep 24, 2015NETGEAR Employee Retired
Hi anyrules,
Welcome to Community!
Does it work when using a different security option? The Airconditioner might not be compatible with WPA2-PSK[AES].
JamesGL
Community Team
- anyrulesSep 25, 2015Aspirant
Hello JamesGL,
only with open network. The name of the device: MAC-558IF-E which is should capable of WPA2-AES encryption.
Please see the installation guide: http://www.mitsubishi-electric.co.nz/materials/Controllers/Manuals/WI-FI/1_Operation/Guide_Wi-Fi_Control_Installation.pdf
Istvan- JamesGLSep 28, 2015NETGEAR Employee Retired
Hi anyrules,
Can you connect it without the use of WPS, like connecting it manually by entering the password?
JamesGL
Community Team- anyrulesSep 28, 2015Aspirant
Hello JamesGL,
unfortunately not possible. The other device has only two button. One for connectin and one for reset..
Istvan
