anyrules
Sep 21, 2015Aspirant
Nighthawk X4 R7500 WPS
Hello, I bought a Mitsubishi air conditioners with wifi adapter. I would like to connect the mentioned device to my home network via WPS. The connection has been created successfully, but the dev...
- Oct 05, 2015
Hello James,
Yes like to Mitsu devices with other router..
Istvan
JamesGL
Oct 02, 2015NETGEAR Employee Retired
Hi anyrules,
I apologize for that one. As you can see the routers WPS is working fine as other devices can connect to it without any problems.
JamesGL
Community Team
anyrules
Oct 05, 2015Aspirant
Hello James,
Istvan
- anyrulesOct 05, 2015Aspirant
Hello James,
WPA2-AES routers we have tested and working fine:
- Apple - A1409
- Asus - RT-N16
- Asus - RT-N66U
- Edimax - BR-6428nS
- Edimax - AR-7267WnA
- Huawei - HG630b
- Micronet - SP916NE
- SMC - SMC7904WBRA-N2
- TP-LINK - TD-W8960N
Istvan
- anyrulesOct 06, 2015Aspirant
Hello James,
I started the problem analisis with contact the support team and they said the following:( I bought the router in January so...)
Dear Nagy,
Your R7500 comes with the following warranty from the date of purchase:
* 90 days basic technical support
* <1 year/2 years> Hardware Warranty
Based on the product registration, your device is no longer eligible for free assistance from a support expert. However, I want to make sure you are aware there are other options available for you to utilize such as:
* Self-help web articles http://support.netgear.com/for_home
* NETGEAR Forums http://forum1.netgear.com
Aside from the above free options, I highly recommend our GearHead Premium Services which will entitle you to phone support for this issue and in addition you also get unlimited support for all your other home networking devices. For more information, you may visit the GearHead website at http://gearhead.netgear.com.
Thank you for choosing NETGEAR.
Annu
Expert ID: 1369
NETGEAR Support Expert
