anyrules's avatar
anyrules
Nighthawk X4 R7500 WPS
Hello, I bought a Mitsubishi air conditioners with wifi adapter. I would like to connect the mentioned device to my home network via WPS. The connection has been created successfully, but the dev...
  • anyrules's avatar
    anyrules
    Oct 05, 2015
    Hello James,
    Yes like to Mitsu devices with other router..
       Istvan
