motorbikematt
Jul 23, 2017Aspirant
Nighthawk X4 R7500v2 Access Control does not work
Frustrating behavior with my device, router firmware version V1.0.3.10 I cannot block a device that is using my network. Advanced>Security>Access Control the checkbox next to Turn On Access Contr...
- Aug 03, 2017
Hi motorbikematt,
Try to reset the router to factory default and manually reconfigure the device.
JamesGL
Aug 03, 2017NETGEAR Employee Retired
Hi motorbikematt,
I tried to replicate your concern but I was not able to reproduce the same behavior. Mine works fine.
- motorbikemattAug 03, 2017AspirantThank you for trying to replicate!! That is interesting data, even if it isn't a solution.
Tell me, when did you buy yours? Is it 'younger' than mine?- JamesGLAug 03, 2017NETGEAR Employee Retired
Hi motorbikematt,
Try to reset the router to factory default and manually reconfigure the device.- JamesGLAug 06, 2017NETGEAR Employee Retired
Hi motorbikematt,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- Dodd52Aug 12, 2017Aspirant
I have the same router and the same issue. I can't block an intruder in my network. I bought my router in Dec 2015.
