motorbikematt's avatar
Jul 23, 2017
Nighthawk X4 R7500v2 Access Control does not work
Frustrating behavior with my  device, router firmware version V1.0.3.10 I cannot block a device that is using my network. Advanced>Security>Access Control the checkbox next to Turn On Access Contr...
  • JamesGL's avatar
    JamesGL
    Aug 03, 2017
    Hi motorbikematt,
    Try to reset the router to factory default and manually reconfigure the device.
