motorbikematt
Jul 23, 2017Aspirant
Nighthawk X4 R7500v2 Access Control does not work
Frustrating behavior with my device, router firmware version V1.0.3.10 I cannot block a device that is using my network. Advanced>Security>Access Control the checkbox next to Turn On Access Contr...
- Aug 03, 2017
Hi motorbikematt,
Try to reset the router to factory default and manually reconfigure the device.
motorbikematt
Aug 03, 2017Aspirant
Thank you for trying to replicate!! That is interesting data, even if it isn't a solution.
Tell me, when did you buy yours? Is it 'younger' than mine?
