Jayo52
Dec 15, 2020Aspirant
Nighthawk x4 r7500v2 ethernet speed very slow
I have a c1100 cable modem. Also a r7500v2 nighthawk x4 router. 200/10mbps service from spectrum. Wifi 5g i pull over 200mbps. Perfect. However I only get 10-20mbps with ethernet. Tried on amazon fire...
Dec 16, 2020Guru - Experienced User
Which firmware version are you on?
If you hardwire into the modem, what speeds do you get?
Any other devices to try?
How are you testing the speeds?
- Jayo52Dec 17, 2020AspirantFirmware v1.0.3.48 , also tried rolling back 2 previous versions with no change in speed, so reset router and did manual update to latest v1.0.3.48
Hardwire to modem pulls 130/17 ( it’s 100/10 port) so modem appears to be working great
Trying on fire tv cube and laptop, also wifes laptop. No change in speeds
Using speedtest.net on laptops, also tried google speedtest. On cube im using analiti- Jayo52Dec 17, 2020AspirantJust to add, ive also tried every lan port on my router with no change in speed. Traffic meter and qos both off. No other ethernet cables hooked to my router besides wan from modem and my cable from router to laptop ( both functioning cat 8). Tested both cables from modem to laptop, each getting 110/17mbps. Not sure what else i can try at this point. Not willing to pay netgear $150 to tell me the router is defective.
- plemansDec 18, 2020Guru - Experienced User
If the 5ghz is hitting 200mbps (and speed from modem only 100mbps), somethings off.
Do you have anything else connected to the cm1100?
its got 2 ethernet ports but only 1 should be useable unless you're using wan port aggregation.
