Carsten_R
Jan 21, 2023Aspirant
Nighthawk x4s -IPV6 Dual Stack Lite (DS-Lite)
Hi all, can someone explain me how to Setup the router for a PPPoE FTTH Connection with IPV6 Dual Stack Lite (DS-Lite) ? I have put in the IPV6 Login credentials for pppoe, get an IPv6 Adress , ca...
michaelkenward
Jan 21, 2023Guru - Experienced User
Which Netgear device are you using?
There are several "x4s" devices.
What are you trying to do?
Carsten_R
Jan 22, 2023Aspirant
I use the Netgear Nighthawk X4S AC2600 Smart Wifi Router Model: 7800, newest Firmware.
The Router worked well for the pur IPv4 login.
I put in the login credentials for a pppoe IPV6 login, get an IPv6 Address, but no IPv4 Adress entry for the DS-Lite.
