Carsten_R
Jan 21, 2023Aspirant
Nighthawk x4s -IPV6 Dual Stack Lite (DS-Lite)
Hi all, can someone explain me how to Setup the router for a PPPoE FTTH Connection with IPV6 Dual Stack Lite (DS-Lite) ? I have put in the IPV6 Login credentials for pppoe, get an IPv6 Adress , ca...
Carsten_R
Jan 22, 2023Aspirant
I use the Netgear Nighthawk X4S AC2600 Smart Wifi Router Model: 7800, newest Firmware.
The Router worked well for the pur IPv4 login.
I put in the login credentials for a pppoe IPV6 login, get an IPv6 Address, but no IPv4 Adress entry for the DS-Lite.
Kitsap
Jan 22, 2023Master
Carsten_R wrote:I use the Netgear Nighthawk X4S AC2600 Smart Wifi Router Model: 7800, newest Firmware.
What specific version of firmware do your have installed? The "newest" does not allow confirmation as their may be other versions.
In the configuration of your router, under Advanced -> Advanced Setup -> IPv6 do you have IPv6 enabled? When enabled, there is a drop down menu that sets the connection type. PPPoE is one of the options.
- Carsten_RJan 22, 2023Aspirant
Here are some screenshots, I hope it helps.
When he is connected he shows two IPv6 Adresses but no Infos about IPv4
- KitsapJan 22, 2023Master
Carsten_R wrote:Here are some screenshots, I hope it helps.
I cannot see inserted images until after a moderator approves them. If you attach the file (different from inserting), one file per message, then I can see them.
What happens when you check your IP here: https://whatismyipaddress.com/
I can now see the screen snips you have posted.
What happens when you check your outside IP addresses here: https://whatismyipaddress.com/
What specific problem are you having?
