Carsten_R
Jan 21, 2023Aspirant
Nighthawk x4s -IPV6 Dual Stack Lite (DS-Lite)
Hi all, can someone explain me how to Setup the router for a PPPoE FTTH Connection with IPV6 Dual Stack Lite (DS-Lite) ? I have put in the IPV6 Login credentials for pppoe, get an IPv6 Adress , ca...
Kitsap
Jan 22, 2023Master
Carsten_R wrote:Here are some screenshots, I hope it helps.
When he is connected he shows two IPv6 Adresses but no Infos about IPv4
I cannot see inserted images until after a moderator approves them. If you attach the file (different from inserting), one file per message, then I can see them.
What happens when you check your IP here: https://whatismyipaddress.com/
Kitsap
Jan 22, 2023Master
I can now see the screen snips you have posted.
What happens when you check your outside IP addresses here: https://whatismyipaddress.com/
What specific problem are you having?
- Carsten_RJan 23, 2023Aspirant
The Test about my IP shows only the IPv6-Address, no IPv4.
here is the IPv6 site of the Router:
And here is the overview:
- KitsapJan 23, 2023Master
You are still inserting screen snips and not attaching them. See attached.
Waiting to see the results from this link: https://whatismyipaddress.com/.
Additional information here: https://whatismyipaddress.com/dual-stack
