jefflisco's avatar
jefflisco
Follower
Dec 14, 2020
Nighthawk X4s AC2200
I have the extender setup correctly and I'm able to connect my devices but my main TV in the living room will freeze and drop the connection. I troubleshooted the issue to elimiate AT&T as the issue or their equipment. When I unplug the extender the problem of the TV freezing or loosing connection goes away. Any ideas on what the problem is?
1 Reply
  • plemans's avatar
    The EX7500 uses bandsteering. But the tv might be connecting to its 2.4ghz signal which is slower and more sensitive to interference. You could try disabling the "onessid" features and setting the tv to the 5ghz signal.
