krohlfs
Jun 02, 2021Tutor
Nighthawk X4S AC2600 Not Sending Wifi
I have the Netgear Nightawk X4S AC2600 router. I have a line that directly connects my laptop to the router, and that is working fine. My computer has internet. However, it is not sending out wifi...
- Jun 02, 2021
So you tried factory reset?
And you pushed and held the wifi on/off button (2nd from the right on the front of the router) for 2 seconds?
You could try reinstalling the firmware in case something is corrupt in the firmware.
Jun 02, 2021Guru - Experienced User
krohlfs
Jun 02, 2021Tutor
Wow, thank you so much, plemans!! I didn't realize the buttons on the front were able to be pushed. I guess somehow/someone must have pushed down the wifi button to turn it off. I feel like an idiot. Wow - I am so sorry! Thank you VERY much for your help and saving me from going out and buying a new router. I am VERY VERY thankful!
- plemansJun 02, 2021Guru - Experienced User
Glad it worked!
I've got turd monkeys that run around my home and they're great at pushing buttons.
- michaelkenwardJun 05, 2021Guru - Experienced User
They are there for the benefit of cats, which like to sit on top of a nice warm router.
