Xbox_Guy
Sep 05, 2018Tutor
Nighthawk X4S AC2600 R7800 Ping Spikes While Gaming
My setup:
Router: Nighthawk X4S AC2600 R7800
Firmware: V1.0.2.58
Modem: Arris TM607
Service Provider: Spectrum
Speed Router is receiving: 234.07Mbps down | 12.38Mbps up
Game Platform: Xb...
- Sep 05, 2018
Some people (including me) have found latency and packet loss issues with firmware 1.0.2.58. Try downgrade to 1.0.2.52 and report back if that has made a difference.
ablatt
Sep 05, 2018Apprentice
- JoshJSep 05, 2018Aspirant
Interesting as I am having the same issue, once I figure out how to downgrade...I'll report back
- Xbox_GuySep 06, 2018Tutor
Thanks for the advice ablatt! I downgraded my firmware from 1.0.2.58 to 1.0.2.52 (making sure to reset the router before and after the downgrade) by following the instructions found here. The difference has been night and day; not a single online game dropped and the ping spikes are completely gone. All I did after downgrading the firmware and resetting the router was renamed both wifi frequencies and set passwords for each. Hopefully this issues gets resolved soon because I'm betting more and more people who upgrade their firmware are going to be hit with this issue.
- NenoeilSep 16, 2018Initiate
Thanks very much for the advise, downgrade to 1.02.52 solved my ping spikes with wifi 5ghz on PC games and XBOX ONE X games. 100% sure the fw 1.02.58 is a faulty one. With 1.02.52 everything works fine in games as before.
