JCRebmann
Nov 04, 2020Aspirant
Nighthawk X4S AC3200 Wi-Fi Cable Modem Router
I have been having internet connectivity issues for a few weeks. Ive been in touch with my internet provider Spectrum a few times now and they have checked their end and say that its the router. I ...
antinode
Nov 04, 2020Guru
> I have been having internet connectivity issues [...]
Not a very detailed description of anything.
> [...] made sure the router has its updates [...]
That's nice, but an actual firmware version would convey more useful
information.
> [...] I cant find anywhere how to do this of if it would even help.
Where, exactly, did you look?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Specify Basic
WiFi Settings". (Note: "cant" is a word, different from "can't".)
> [...] of if it would even help.
Knowing as much as I do about your (unspecified) "internet
connectivity issues", I can say with complete confidence that I have no
idea whether using a different radio channel would help, but it's a
pretty easy experiment to run.
- JCRebmannNov 04, 2020AspirantWow!! That answer was very curt, negative and not at all helpful. If I knew what I was doing, I wouldn’t be asking for help! And correcting my grammar?? Really?? Thanks for nothing.
- antinodeNov 04, 2020Guru
> [...] not at all helpful. [...]
Did you have trouble finding the User Manual section which tells you
exactly how to do what you asked? Was is unclear in some way?> [...] And correcting my grammar?? [...]
Might be more spelling (or lazy typing) than grammar, depending on
exactly what you don't know. It's a free educational service. You're
welcome. (I didn't bother complaining about your misuse of "its", did
I? Yow. Some people complain when they're hanged with a new rope.)> [...] Thanks for nothing.
You seem to have trouble distinguishing between "nothing" and
"exactly what I asked for (at least)". This might be a bigger handicap
than bad grammar, but I may be powerless to help with that.
