Mallowsm
Nov 19, 2020Aspirant
Nighthawk x4s d7800, dsl port question
Can I please ask what connection is on the back of this router for the DSL side, I have tried both RJ11 and standard ethernet, neither fit. Does anyone know what connection this is, from the grey por...
antinode
Nov 19, 2020Guru
> [...] what connection is on the back of this router for the DSL side,
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Technical
Specifications" and "DSL".
> [...] I have tried both RJ11 and standard ethernet, neither fit. [...]
The User Manual says "One RJ-11 asynchronous DSL (ADSL/VDSL) port".
That's what I'd expect. I can't see what you're doing.
> [...] the box that's coming into the property from my home
I can't see any of that, either.
