Don10e
Jan 06, 2023Follower
Nighthawk X4S r7800 - DNS settings
We had issues with our ISP (Cox) and to connect to the internet I had to manually change the DNS on our phones and PC's. Since then my Nest thermostat can connect to the router, but can't get on the ...
Jan 06, 2023Guru - Experienced User
Really shouldn't need to change DNS settings unless something is happening at the ISP or ISP DNS level.
Try changing from ISP DNS to Google DNS or cloudfare on the router under Advanced tab/Internet setup.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
