Don10e
Jan 06, 2023Follower
Nighthawk X4S r7800 - DNS settings
We had issues with our ISP (Cox) and to connect to the internet I had to manually change the DNS on our phones and PC's. Since then my Nest thermostat can connect to the router, but can't get on the ...
michaelkenward
Jan 06, 2023Guru - Experienced User
What was the issue? Sounds like you got bad advice from the ISP.
Go back to square one and you might find a better solution that does not screw up everything else.
