187-J4CK4L
Feb 04, 2019Aspirant
Nighthawk X4S R7800 - Using Apple TV
I just purchased a 64GB Apple TV 4K. I am having trouble getting it to see my Windows 10 PC on my network. I have enabled and signed into Home Sharing in iTunes on my PC and on the Apple TV and selec...
- Feb 06, 2019
I had the same problem. In my case, this was due to an incompatibility between the R7800 and my 16-port Netgear Ethernet switch that breaks the Apple Bonjour protocol (A number of people have reported this problem, which also breaks Apple AirPrint). The fix was to turn off IGMP Snooping in the Ethernet switch via the web interface to the switch.
microchip8
Feb 05, 2019Master
Does you Apple TV even gets an IP address from the router?
187-J4CK4L
Feb 05, 2019Aspirant
Yes, the Apple Tv works perfectly fine. It just dose not find my computer on my network.
- microchip8Feb 05, 2019Master
Might be something related to your PC network. I can't tell. I also don't know how you expose the network for the Apple TV to find it. Is it DLNA, Samba, etc?
