187-J4CK4L's avatar
187-J4CK4L
Nighthawk X4S R7800 - Using Apple TV
I just purchased a 64GB Apple TV 4K. I am having trouble getting it to see my Windows 10 PC on my network. I have enabled and signed into Home Sharing in iTunes on my PC and on the Apple TV and selec...
  • pec967's avatar
    Feb 06, 2019
    I had the same problem. In my case, this was due to an incompatibility between the R7800 and my 16-port Netgear Ethernet switch that breaks the Apple Bonjour protocol (A number of people have reported this problem, which also breaks Apple AirPrint). The fix was to turn off IGMP Snooping in the Ethernet switch via the web interface to the switch.
