187-J4CK4L
Feb 04, 2019Aspirant
Nighthawk X4S R7800 - Using Apple TV
I just purchased a 64GB Apple TV 4K. I am having trouble getting it to see my Windows 10 PC on my network. I have enabled and signed into Home Sharing in iTunes on my PC and on the Apple TV and selec...
- Feb 06, 2019
I had the same problem. In my case, this was due to an incompatibility between the R7800 and my 16-port Netgear Ethernet switch that breaks the Apple Bonjour protocol (A number of people have reported this problem, which also breaks Apple AirPrint). The fix was to turn off IGMP Snooping in the Ethernet switch via the web interface to the switch.
187-J4CK4L
Feb 06, 2019Aspirant
I looked for that setting and found “Disable IGMP Proxying” and it was checked. So I unchecked, enabling it and now it seems to be working. Thank you for your help. That is way more than I got out of the Apple support pages. Those people were useless😂.
pec967
Feb 06, 2019Luminary
IGMP Snooping Proxy is a different protocol from IGMP Snooping. What Ethernet switch do you have?
Below is the Netgear article on IGMP Snooping.
IGMP snooping is enabled by default on NETGEAR Web Managed Plus Switches. This can help to prevent unwanted traffic being sent to clients who do not request it and can improve network performance.
In certain situations, this setting can cause problems with applications (e.g. TiVo) that rely on multicast traffic to be flooded to all ports.
To disable this setting, follow the steps below.
- You must know the IP address of the switch. If you do not know the IP address of the switch, you can find it by discovering the switch using the ProSAFE Plus Configuration Utility
- Ensure that the firmware on the switch is up to date
- Open a web browser.
- In the address bar of the web browser, type the IP address of the switch and press Enter.
- Type the admin password of the switch (the default password is password) and click Login.
- Go to System - MultiCast.
- Set IGMP Snooping Status to Disable.
- Set Block Unknown Multicast Address to Disable if not already disabled.
- Click Apply.
- Go to System - Management - Broadcast Forwarding.
Note: The Broadcast Forwarding option is only applicable to GS116Ev2, JGS524Ev2, JGS516PE and JGS524PE models of Web Managed Plus Switch. - Set Broadcast Forwarding Method to Hardware.
- Click Apply.
- 187-J4CK4LFeb 06, 2019AspirantI have the Nighthawk X4S R7800.
- pec967Feb 06, 2019Luminary
What I have is an external 16-port Ethernet switch connected to the R7800. The problem I had related to the interaction between the 16-port Ethernet switch and the R7800. Do you have any external Ethernet switches?
I assume what you have toggled is the R7800 configuration for IGMP Proxy in WAN Setup? I had tried toggling this at one time, and I was able to get the AppleTV to show up for a few hours after a reboot, but it would then disappear.
I have my computer and Apple TV plugged right into my R7800 Wi-fi router. I have a Netgear 8 port Gigabit Switch coming off the R7800 going to other devices.
