187-J4CK4L
Feb 04, 2019Aspirant
Nighthawk X4S R7800 - Using Apple TV
I just purchased a 64GB Apple TV 4K. I am having trouble getting it to see my Windows 10 PC on my network. I have enabled and signed into Home Sharing in iTunes on my PC and on the Apple TV and selec...
- Feb 06, 2019
I had the same problem. In my case, this was due to an incompatibility between the R7800 and my 16-port Netgear Ethernet switch that breaks the Apple Bonjour protocol (A number of people have reported this problem, which also breaks Apple AirPrint). The fix was to turn off IGMP Snooping in the Ethernet switch via the web interface to the switch.
pec967
Feb 06, 2019Luminary
What I have is an external 16-port Ethernet switch connected to the R7800. The problem I had related to the interaction between the 16-port Ethernet switch and the R7800. Do you have any external Ethernet switches?
I assume what you have toggled is the R7800 configuration for IGMP Proxy in WAN Setup? I had tried toggling this at one time, and I was able to get the AppleTV to show up for a few hours after a reboot, but it would then disappear.
187-J4CK4L
Feb 06, 2019Aspirant
I have my computer and Apple TV plugged right into my R7800 Wi-fi router. I have a Netgear 8 port Gigabit Switch coming off the R7800 going to other devices.
- 187-J4CK4LFeb 06, 2019Aspirant
This is turning into the biggest headache and this Apple crap is either gonna be smashed with a hammer or returned to the store. First thing, I don't understand why I cannot connect to my router login through ethernet, it only works when my DESKTOP COMPUTER is using my USB wi-fi adapter, STUPID!!! My computer is right next to my router and modem, I will not use wi-fi!! Second, after I got the Apple TV working, I disconnected my wi-fi adapter and reconnected my PC to ethernet, the crapple tv no longet connects to my PC. This makes no FKN sense!!!!!!! The instructions for changing the IGMP settings above do not apply to the model of wi-fi router I have. I don't have a System - Multicast selection.
- pec967Feb 06, 2019Luminary
I have two pieces of equipment: (1) R7800 router and (2) external 16-port Ethernet switch connected to the R7800. The problem I experienced, which had the same symptoms as you described, was due to the interaction of these two pieces of equipment.
I would set the IGMP Proxy setting in the router back to its default and then power everthing down -- modem, R7800, PC, AppleTV, etc. Power up the modem, and once it is up power up the R7800. After the router is up, power up the rest of your equipment, start iTunes, and see if the AppleTV shows up.
