franklyfresh
Nov 29, 2021Aspirant
Nighthawk X4S R7800 - WiFi less than half the speed of my modem/router combo and a third of ethernet
I've been on the struggle bus for hours now and decided to solicit help from the experts here. My router is delivering really poor WiFi speeds. Ethernet connection form the modem or from the router a...
michaelkenward
Nov 30, 2021Guru - Experienced User
franklyfresh wrote:
I don't expect Wifi to get anything close to the ethernet speed of 1gb but I can't beleive the ISP provided modem/router combo was delivering 2x the wireless speeds vs. the expensive netgear! There's got to be something going on with the router...
That's good. Because wifi will never deliver wired speeds.
For all your long saga, you say nothing about the wifi clients. These are the things that set your wifi speeds.
You might find it instructive to read up a bit on wifi speeds and the many misconceptions surrounding them.
It might be worth a bit of background reading.
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
@duckware knows their stuff and can bust a few myths and cut through marketing hype.
The bottom line is that the 200-350 Mbps you get is better than many wifi clients can hope to achieve.
Another common confusion is between "connection rate" and speed. But that's another story.
franklyfresh
Nov 30, 2021Aspirant
Thanks for the reply and link!
My adapter runs 2x2 which should get me actual throughout of 600mbps. The main reason I am puzzled is that I have been getting 600-650mbps via WiFi for months through my ISP provided modem/router. So there is no issue with my devices receiving 600mbps+ speeds. It was not until I switched to the Nighthawk that the speed was cut in half.
- franklyfreshDec 01, 2021Aspirant
bump
- KitsapDec 01, 2021Master
Under Advanced -> Wireless Setup, make sure you do not have a check mark beside Enable Smart Connect.
Under Advanced -> Wireless Setup, make sure you do not have a check mark beside Enable 20/40 MHz Coexistence.
Use different SSID's for the 2.4 GHz and 5 GHz bands.
You should consider using the Voxel refined version of the firmware. Link is: Voxel
