franklyfresh
Nov 30, 2021Aspirant
Nighthawk X4S R7800 - WiFi less than half the speed of my modem/router combo and a third of ethernet
I've been on the struggle bus for hours now and decided to solicit help from the experts here. My router is delivering really poor WiFi speeds. Ethernet connection form the modem or from the router a...
franklyfresh
Dec 01, 2021Aspirant
bump
Kitsap
Dec 01, 2021Master
Under Advanced -> Wireless Setup, make sure you do not have a check mark beside Enable Smart Connect.
Under Advanced -> Wireless Setup, make sure you do not have a check mark beside Enable 20/40 MHz Coexistence.
Use different SSID's for the 2.4 GHz and 5 GHz bands.
You should consider using the Voxel refined version of the firmware. Link is: Voxel
