Shaikhisa39
Jan 11, 2020Aspirant
Nighthawk x4s r7800 40Mhz Force Enab
help me in this as i am using the nighthawk x4s r7800 router it's not giving me an option to use it for 40Mhz Or 80Mhz and its Also capable of 160Mhz bt its not showing an option trying to change chan...
- Jan 19, 2020
80 MHz width is on by default regardless which channel you use. If you want to force 160 MHz width, you need to use a DFS channel, usually between 52 and 140. As I mentioned, your wifi device needs to support 160 MHz width too or else it won't work
duckware
Jan 11, 2020Prodigy
Netgear calls MHz channel width 'mode' (http://duckware.com/wifi#netgearmode)
But in almost all cases, you want to keep it on 80 MHz. Clients will just connect at the maximum channel width they can. If that is 80 MHz, great. But if that is 20/40, clients will connect at 20/40 just fine in 5 GHz (using 802.11n).
I need to research this more, but I believe if you turn off 80 MHz mode, you are actually turning *off* 802.11ac support and turning the router into a 802.11n (dual band) router.
For 160, go to Advanced / Advanced Setup / Wireless Settings and check 'Enable HT160'. Not sure what happens after that, but that will get you started.
microchip8
Jan 11, 2020Master
For the 2.4 GHz band you can enable 40 MHz width by going to Advanced -> Setup -> Wireless Setup and uncheck the "Enable 20/40 MHz Coexistence" box. This will force it to use 40 MHz width. This is generally not recommended if you have many other networks that operate at 20 MHz in your area
For the 5 GHz band, you can force 160 MHz width by going to Advanced -> Advanced Setup -> Wireless Setup
- Shaikhisa39Jan 12, 2020AspirantYes i have tried both of them by checking as sell as unchecking .. it's only getting 20Mhz have enabled HT160 as well but no solution
- microchip8Jan 12, 2020Master
The 2.4 GHz band does not support 80 MHz, only the 5 GHz does. For 160 MHz on the 5 GHz band, you need to have a compatible adapter. After enabling or disabling, you need to reconnect your device(s). I just tested here on my Android phone, and 40 MHz width works with no issues on the 2.4 GHz band
PS: try to write in proper English as it's difficult to understand when you talk like an uneducated person
- Shaikhisa39Jan 19, 2020AspirantSorry For My Bad English .. As I Was Not Getting Word How To Explain That Thing .. And I Believe You Are The Only One Who Find It Difficult To Understand My English .. Well That's Okay I Will Try Your Suggestion As Well .. And Will Get Back To You Wether It Works Or Not..
