Shaikhisa39
Jan 11, 2020Aspirant
Nighthawk x4s r7800 40Mhz Force Enab
help me in this as i am using the nighthawk x4s r7800 router it's not giving me an option to use it for 40Mhz Or 80Mhz and its Also capable of 160Mhz bt its not showing an option trying to change chan...
- Jan 19, 2020
80 MHz width is on by default regardless which channel you use. If you want to force 160 MHz width, you need to use a DFS channel, usually between 52 and 140. As I mentioned, your wifi device needs to support 160 MHz width too or else it won't work
microchip8
Jan 11, 2020Master
For the 2.4 GHz band you can enable 40 MHz width by going to Advanced -> Setup -> Wireless Setup and uncheck the "Enable 20/40 MHz Coexistence" box. This will force it to use 40 MHz width. This is generally not recommended if you have many other networks that operate at 20 MHz in your area
For the 5 GHz band, you can force 160 MHz width by going to Advanced -> Advanced Setup -> Wireless Setup
Shaikhisa39
Jan 12, 2020Aspirant
Yes i have tried both of them by checking as sell as unchecking .. it's only getting 20Mhz have enabled HT160 as well but no solution
- microchip8Jan 12, 2020Master
The 2.4 GHz band does not support 80 MHz, only the 5 GHz does. For 160 MHz on the 5 GHz band, you need to have a compatible adapter. After enabling or disabling, you need to reconnect your device(s). I just tested here on my Android phone, and 40 MHz width works with no issues on the 2.4 GHz band
PS: try to write in proper English as it's difficult to understand when you talk like an uneducated person
- Shaikhisa39Jan 19, 2020AspirantSorry For My Bad English .. As I Was Not Getting Word How To Explain That Thing .. And I Believe You Are The Only One Who Find It Difficult To Understand My English .. Well That's Okay I Will Try Your Suggestion As Well .. And Will Get Back To You Wether It Works Or Not..
- Shaikhisa39Jan 19, 2020AspirantAnd One More Thing I Will Try To Explain You In A Simple English Don't Know Wether You Will Get It Or Not When I Was Trying To Find A Solutions On It Many Of The Post Suggest That U Need To Set Your Wifi On A Specific Channel Which Supports 80Mhz Or 160 Mhz on 5Ghz But There Is No Channel Showing Which Supports 80Mhz Or 160Mhz ..
- duckwareJan 19, 2020Prodigy
Can you install WiFi Analyzer (open-source) and a device a report back what the app reports for the router's SSID's being broadcast?
