wiseonewill
Mar 13, 2017Aspirant
Nighthawk X4S R7800 5G going in and out
Hello, I purchased a Nighthawk(R) X4S R7800 just over 5 months ago and started having issues with it within the last few days. The wireless started going out, I thought it might be the ISP but al...
- Mar 28, 2017
Another firmware upgrade was made available and I installed it over the weekend. So far, this appears to have resolved the issue. Hopefully this continues.
JamesGL
Mar 15, 2017NETGEAR Employee Retired
Hi wiseonewill,
When you reset the router, try not to load the backup and reconfigure it manually. Try changing the channel of 5GHz. By the way, how many devices connected to 5Ghz?
- JamesGLMar 19, 2017NETGEAR Employee Retired
Hi wiseonewill,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- wiseonewillMar 20, 2017Aspirant
Hi JamesGL,
Thanks for your reply. I've been very busy and haven't had a chance to reset the router again.
I've switched all my devices to the 2.4ghz network and they are connected so it hasn't been as pressing.
There are probably between 5 and 15 devices connected at any given time. All devices that were on the 5ghz stopped connecting at the same time just over a week ago.
Thanks,
Will
- JamesGLMar 20, 2017NETGEAR Employee Retired
Hi wiseonewill,
Provide us feedback once you have done another reset and manually reconfiguring the device.
