Twinsen
Jan 13, 2022Tutor
Nighthawk X4S R7800 does not upgrade
Just read the news about this router being vulnerable for hackers attacks and found a new firmware file on netgear site. However, the router itself does not accept it telling me that this new firmwa...
- Jan 13, 2022
Under the downloads section click on "+view previous versions"
Try a stepped approach. Go a couple versions newer and see if you can update.
Jan 13, 2022Guru - Experienced User
the version you're on is around 22 versions behind. You might try doing a stepped process versus going from 0 to 100.
- TwinsenJan 13, 2022Tutor
Thanks! I believe I can only find the most recent version on netgear site? Where should I look for the "middle" versions?
- plemansJan 13, 2022Guru - Experienced User
Thank you, it helped! I've gone from 2.04 to 2.28 to 2.40 to 2.52 to 2.68 to 2.80 to 2.86 (previous version) to 2.90 and it worked this way!
- mickeydeanJan 13, 2022Aspirant
My router is on firmware version V1.0.2.82 and I am encountering the same error
