Twinsen
Jan 13, 2022Tutor
Nighthawk X4S R7800 does not upgrade
Just read the news about this router being vulnerable for hackers attacks and found a new firmware file on netgear site. However, the router itself does not accept it telling me that this new firmwa...
- Jan 13, 2022
Under the downloads section click on "+view previous versions"
Try a stepped approach. Go a couple versions newer and see if you can update.
Jan 13, 2022Guru - Experienced User
the version you're on is around 22 versions behind. You might try doing a stepped process versus going from 0 to 100.
mickeydean
Jan 13, 2022Aspirant
My router is on firmware version V1.0.2.82 and I am encountering the same error
