Nighthawk86
Mar 06, 2021Aspirant
Nighthawk X4S R7800 Firmware Problems
My router keeps losing Internet connection since firmware version V1.0.2.68. I installed the latest firmware V1.0.2.80 and the problem keeps happening. I have to reboot the router every time Internet...
Nighthawk86
Mar 07, 2021Aspirant
The Wireless and Wired connections lose internet. I have to login and reboot to restore internet.
The router is in regular mode.
They know it’s not the modem because they can see if it loses connection. The modem is a Netgear CM600 and it is not a router.
I recently installed V1.0.2.62 and went directly to V1.0.2.80 to see if that fixes the problem.
microchip8
Mar 07, 2021Master
firmware .80 is quite buggy. You should stay on .58 or .62
- Nighthawk86Mar 07, 2021Aspirant
I just installed .58 to see if that stops the problem from happening.
