Ashers
Nov 25, 2020Tutor
Nighthawk X4S R7800 firmware removed telnet access
I see that the option to enable Telnet in the debug page (192.168.1.3/debug.htm) has been removed in a recent firmware update to the R7800. The option is visible in V1.0.2.68 firmware, but not in the latest firmware.
Unfortunately, I need telnet to fix the R7800 bug that sends all URLs to routerlogin.net when in AP mode, which Netgear still hasn't fixed:
Does anyone know how to enable telnet in the latest firmware?
You can't via the official route.
To get telenet back via the offical route, you'd need to downgrade the firmware.
antinode had a program to enable telenet but I admit to knowing nothing about it or if it'd work in your case.
- AshersTutorMany thanks. I think I will stick with V1.0.2.68 of the firmware, as I've read many complaints about the newer firmware. But if I ever do upgrade, I will try that application to see if it works.
