benprowley
May 31, 2017Tutor
Nighthawk X4S R7800 Flashing amber power light intermittently with eSATA white light. Amber, white
This is a Netgear Nighthawk x4s ac2600 smart wifi router model R7800 with the latest firmware. Router is flashing back and forth from the Amber power LED to the White eSATA LED. Back and forth contin...
- May 31, 2017
From user manual:
"Power LED Stays Amber When the router is turned on, the Power LED lights amber for up to two minutes and then turns white. If the LED does not turn white, this indicates a problem with the router. If the Power LED is still amber three minutes after you turn on power to the router, do the following: • Cycle the power to see if the router recovers. • Press and hold the Reset button to return the router to its factory settings. For more information, see Factory Settings on page 171. If the error persists, a hardware problem might be the cause. Contact technical support at netgear.com/support."
Cant find anything regarding the eSata LED and it's interaction with the Power LED.
May 31, 2017Guru - Experienced User
From user manual:
benprowley
May 31, 2017Tutor
I couldn't get it stable and I was able to get it to load the FW update wirelessly, but when it restarts from the update it goes back to that flashing pattern. Yeah I think the ethernet ports are blown.... why I have no clue especially with the modem still working. I pulled out my old WNDR3700 and its working. I'm just waiting to hear back from netgear tech support now.
