benprowley
May 31, 2017Tutor
Nighthawk X4S R7800 Flashing amber power light intermittently with eSATA white light. Amber, white
This is a Netgear Nighthawk x4s ac2600 smart wifi router model R7800 with the latest firmware. Router is flashing back and forth from the Amber power LED to the White eSATA LED. Back and forth contin...
- May 31, 2017
From user manual:
"Power LED Stays Amber When the router is turned on, the Power LED lights amber for up to two minutes and then turns white. If the LED does not turn white, this indicates a problem with the router. If the Power LED is still amber three minutes after you turn on power to the router, do the following: • Cycle the power to see if the router recovers. • Press and hold the Reset button to return the router to its factory settings. For more information, see Factory Settings on page 171. If the error persists, a hardware problem might be the cause. Contact technical support at netgear.com/support."
Cant find anything regarding the eSata LED and it's interaction with the Power LED.
JamesGL
Jun 04, 2017NETGEAR Employee Retired
Hi benprowley,
Please try to load the firmware via TFTP.
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
benprowley
Jun 05, 2017Tutor
The only problem with this solution is that, when I plug the computer in via a wired connection it does not see any network. The only way I can talk with the switch is over wifi. Will this solution work over wifi?
- FURRYe38Jun 05, 2017Guru - Experienced User
Are you setting a Static IP address on the wired connection? I believe you have to set a static IP address on the PC to maintain the connection, you can't use DHCP as theres nothing to get from the router. The DHCP server is not working.
- benprowleyJun 05, 2017Tutor
What I mean is when I plug my ethernet connection in from my computer to the internet rj45 port or any of the other rj45 ports it comes up as not being connected in my LAN and I cannot do what the instructions say to do. any ideas?
I believe you have to set a static IP address on the PC LAN adapter to maintain the connection. Auto Obtain IP addressing will not work.
