Alex58's avatar
Alex58
Tutor
Jun 13, 2024
Nighthawk X4S R7800 OVPN multiple issues
Have VPN connection problem. it worked years ago but then suddenly stopped and nothing helped. Trying to approach this issue again but it seems the configuration provided by the modem does not work at all.
after adding/commenting these lines in config;
data-ciphers AES-128-CBC
;comp-lzo
;verb 0
have this in the log:
Fri Jun 14 02:38:17 2024 TCP/UDP: Preserving recently used remote address: [AF_INET]99.234.XX.XX:YYYYY
Fri Jun 14 02:38:17 2024 UDPv4 link local: (not bound)
Fri Jun 14 02:38:17 2024 UDPv4 link remote: [AF_INET]99.234.XX.XX:YYYYY (masked IP)
Fri Jun 14 02:38:18 2024 TLS error: Unsupported protocol. This typically indicates that client and server have no common TLS version enabled. This can be caused by mismatched tls-version-min and tls-version-max options on client and server. If your OpenVPN client is between v2.3.6 and v2.3.2 try adding tls-version-min 1.0 to the client configuration to use TLS 1.0+ instead of TLS 1.0 only
Fri Jun 14 02:38:18 2024 OpenSSL: error:0A000102:SSL routines::unsupported protocol:
Fri Jun 14 02:38:18 2024 TLS_ERROR: BIO read tls_read_plaintext error
Fri Jun 14 02:38:18 2024 TLS Error: TLS object -> incoming plaintext read error
Fri Jun 14 02:38:18 2024 TLS Error: TLS handshake failed
Fri Jun 14 02:38:18 2024 SIGUSR1[soft,tls-error] received, process restarting
did anyone have the same issue?
1 Reply
  • FURRYe38's avatar
    You using external VPN services or something on the router?
    What FW version is loaded on the router?
    Try Voxels 3rd party FW for the R7800?
