callum1980
May 25, 2023Aspirant
Nighthawk X4S R7800 showing wrong country or location
I have a nighthawk X4S R7800 used as an access point, connected to my ISPs (sky broadband) router. The Sky router when I am connected to it directly works well (but it doesnt have good range, hence ...
May 25, 2023Guru - Experienced User
If the R7800 is in AP mode, its getting its IP address info from the sky box.
- callum1980May 25, 2023Aspirant
plemans but the sky router, when im connected directly to that (either via ethernet or wifi) works ok i.e. im in the correct country.
