callum1980
May 25, 2023Aspirant
Nighthawk X4S R7800 showing wrong country or location
I have a nighthawk X4S R7800 used as an access point, connected to my ISPs (sky broadband) router. The Sky router when I am connected to it directly works well (but it doesnt have good range, hence ...
May 25, 2023Guru - Experienced User
If the R7800 is in AP mode, its getting its IP address info from the sky box.
callum1980
plemans but the sky router, when im connected directly to that (either via ethernet or wifi) works ok i.e. im in the correct country.
